suby01 wrote:exactly. my cobbs is FS if your looking for one.
Engine malfunction.4drsleeper wrote:
Sure. I'm interested. But I have to ask why? If you've gotten such great results why would you sell it. I'm assuming you don't plan on making any adjustments so you're selling the software. Let me know.
Broken crank.RobTurbo wrote:Can you explain the malfunction?
All four ports on the magnaflow are all connected to each other. The exhaust gases from each bank are actually mixed in the x-over muffler.AZhitman wrote:That's NOT an X-pipe.
As far as I can tell, it's a dual-in dual-out Magnaflow pre-muffler, which makes no sense in this application.
http://www.magnaflow.com/02pro...=8203
A tangentially-siamesed crossover (X-pipe) looks like this:
I think the final consensus was the aftermarket UR pulley may have been involved. Anything that could contribute to a different balance of the crank either vertically or in the long direction could cause issues especially if it were to introduce a different set of engine criticals other than design. However you also have high flow cats which on various engines can cause issues if they fail. You also have tuning. All of these are something to consider, there may be some benefits but along with that there are almost always risks that come with them.RobTurbo wrote:What? A broken crank when he was only pushing 300hp at the wheels? Doesnt quite add up in my head. Is there something I am missing?
My other car came with a collector, a muffler and resonator. Now it has a collector, a muffler and resonators. In its case the collector looks like a fairly long muffler in either a 2 into 2 or a 2 into 1 arraignment depending on model.AZhitman wrote:Fair enough.
Not a bad idea, I guess - combining a pre-muff with the crossover.
I'd still prefer resonators and a non-perforated crossover.
I'd have to see the one that FI is using, cut open.RobTurbo wrote:why do you still prefer resonators and a non-perforated crossover?
advantages and disadvantages being....?
