hello all, I am a new member on the site, I have an 07 G35X SEDAN with no navi, and I am looking to replace all the OEM speakers and add a sub, with a 5 channel amp to run it all, but keep the OEM headunit in place. Will a free-air sub-woofer work in my car using the rear deck cut out? I measured the cut and it is 10inches. Will the base/sound suck? Or will I need to add a box in the truck, I really don't want to do that, but I would love to hear some recommendations on this. And will I need a LOC (line output converter) so that the original car headunit can work with the aftermarket speakers, sub, amp? is a line output converter even necessary if an amp has speaker level inputs?
Thanks everyone for any thoughts and help.
Cheers..
BTW here is what I was recommended by Crutchfield: http://www.crutchfield.com/s_161LC6IG/A ... ml?tp=6870
