Hello all, I am new to this site. I have an '07 G35x (sedan) and recently had the VDC, ABS, and Slip lights come on. I took it to the local dealer to have the car scanned and the C1142 code came up indicating ABS pressure sensor. I will use the diagnostic procedures listed in the service manual, however, if it turns out to be the sensors themselves, I have read elsewhere (before I found this site) that if it is, then the entire ABS control unit (actuator), is the only way to purchase these sensors.
Has anyone else encountered this issue and did you happen to find a supplier who will sell the sensors only? I am not keen on dropping nearly $1400 on an entire new actuator. Any help here would be greatly appreciated.
