07 G35 sedan tweaks
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
zozoka1212
Car: 08 Infiniti G35x
I was searching on the net and found these tweaks. Any of you guys know about this option. Apparently when the car hooked up to the computer @ the service they can change it. I'll go and ask the dealer about this next month when I take it in for service.
Door Lock/Unlock (with single click on keyfob)Mode 1: Unlock left front door onlyMode 2: Unlock all doors
Anti-lock Out (prevents locking keys in car)Mode 1: Master door lock switch can activate door locks w/ key in ignitionMode 2: Master door lock switch cannot activate door locks w/ key in ignition
Dome Lamp TimerMode 1: Interior lamp comes on when left front door is unlockedMode 2: Interior lamp does not come on when left front door is unlocked
Retained Power (Amount of time windows and sunroof will operate after turning off ignition)Mode 1: 45 secondsMode 2: No delay (Will not operate after ignition key is turned off)Mode 3: 2 minutes
Auto Light On (headlights turn on as it gets dark)Mode 1: Factory settingMode 2: Lights come on sooner than factory settingMode 3: Lights come on later than factor settingMode 4: Lights come on later than Mode 3
Head Lamp Battery Saver (applies when headlights left in “on” position, not in “auto.”Mode 1: Shuts lamps off after 5 minutesMode 2: No time delay (headlights turn off immediately)
Headlamp Illumination delay (time headlights remain on after exiting car when headlight is in the “auto” position)Mode 1: 45 secondsMode 2: No Delay (lights turn off immediately)Mode 3: 30 SecondsMode 4: 1 minuteMode 5: 1 ½ minutesMode 6: 2 minutesMode 7: 2 ½ minutesMode 8: 3 minutes
Hazard and Horn Reminder Mode (key fob allows you to choose between modes 1 & 2, but there are 4 others)Mode 1 (C Mode): Lock = 2 flash, 1 horn /// Unlock = 1 flash, 0 hornMode 2 (S Mode): Lock = 2 flash, 0 horn /// Unlock = 0 flash, 0 hornMode 3: Lock = 0 flash, 0 horn /// Unlock = 0 flash, 0 hornMode 4: Lock = 2 flash, 0 horn /// Unlock = 1 flash, 0 hornMode 5: Lock = 2 flash, 1 horn /// Unlock = 0 flash, 0 hornMode 6: Lock = 0 flash, 1 horn /// Unlock = 1 flash, 0 horn
Remote Auto Locking Function Mode (Doors automatically lock after exiting car)Mode 1: 5 minute delayMode 2: Function disabledMode 3: 1 minute delay
Remote Panic Alarm Operation Mode (activates when button on keyfob held for approx. __)Mode 1: .5 secondsMode 2: Function disabledMode 3: 1.5 seconds
Remote Trunk Open Operation Mode (activates when button on keyfob held for approx. __)Mode 1: .5 secondsMode 2: Function disabledMode 3: 1.5 seconds
Remote Power Window Down Operation Mode (activates when button on keyfob held for approx. __)Mode 1: 3 secondsMode 2: Function disabledMode 3: 5 seconds
Zozoka
torbach1
Car: 2009 Infiniti M45x
Hey Zozoka:
A lot of these are actually available through the settings without the dealer. I haven't looked for all of them, but several are.
Regards,Tamir
zozoka1212
Maybe I should dig in the setting before I go to the dealer. Thanks for the info.
Zozoka
Return to “G35 and G37 Interior, Exterior and Audio”
