07 G35 Headlights
G35_Rican30
Car: 2007 Infiniti G35 coupe
Just wondering, i have an 07 g35 coupe with the keyless entry...every time i turn off the car my headlights stay on for approx 20 sec or so, just wondering if i can change that setting
joe603
Car: 2014 Durango R/T
Are they set to "auto"? I know on the 07 sedan there is an adjustment on how long they stay on after the car is shut off.
cde2k7
Car: 2007 Serengeti Sand G35S AT Sedan - Prem - Nav
Press "Settings", go over to "Comfort & Conv.", go down to "Auto Headlights Off Delay" and choose from 0, 30, 45, 60, 90, 120, 150, or 180 seconds. The default is 45 seconds.
G35_Rican30
ok i have the nav package on my 07 g35 coupe but i dont see any comfort and conv button or setting......is there any way to change the headlight settings
G_whizz
Car: 2010 G37 Coupe Sport
joe603 wrote:Are they set to "auto"? I know on the 07 sedan there is an adjustment on how long they stay on after the car is shut off.
See above
G35_Rican30
yes my lights are in the auto position, if i move them to a diff position does the comfort and conv selection come up or am i stuck with the light delay as is?
gwoods
Car: 2013 Infiniti M37x
1999 Nissan Altima SE limited 5spd
1992 Miata (soon to be turbo)
1965 Cj-5 with 327 v8
2012 Toyota Sequoia Limited
Its in the settings below the LCD screen there should be a button that says settings.
You can even adjust how sensitive they are to darkness.
joe603
Just to clear everyone up...the 2007 G35 coupe does NOT have the comfort and conv selection. This is a new feature for the 2007 G35 SEDAN and 2008 G37 coupe.
Basically, if you have the blue interior lights, then you can adjust the shutoff time for the headlights; if you have amber lights, then there isn't an adjustment (that I know of).
Now with the lights in the AUTO setting, they will stay on for a set amount of time. If you select "OFF" they will simply turn off.
Hope this helps
gwoods
oh!
G35_Rican30
Thanks alot joe, i sat in my car for about 45 minutes messing with my car trying to figure this out
99QX4
Car: '07 G35, '05 FX35
I see your in Brooklyn, you should come to the G cruise!
zerothread?id=301779
G35_Rican30
thanks for the invite, honestly i would like to but i dont live in brooklyn anymore, i'm originally from there but i moved away from NYC back in 97' after i joined the Navy....right now i live in maryland and i'm looking for some fellow g35 owners there but not having any luck
cde2k7
You may want to check with the dealer and see if they have a way to change the settings with their computers.
