07fronty »
https://forums.nicoclub.com/07fronty-u249154.html
Fri Mar 13, 2015 9:36 am
My 07 Frontier SE CC 4x4 4L AT will not crank. It does not turn over. I turn the key to RUN and it looks fine, then the headlights come on and the engine fan starts. The engine is stone cold, and no daytime running lights. Headlight switch is OFF. Turn to START and the panel lights stay on, fan and HLs on, but no crank, no solenoid chatter, nothing.
Two days before it quit I got a BAFX OBD code reader from Amazon to use with Torque for Android. Hooked the reader up and played some, drove to town and back watching some of the Torque gauges. Pulled the reader for the night. Next day, plugged code reader in and did my usual errands with Torque monitoring things. Got home and parked, did not remove the reader. Truck sat for about 26 hours and now will not crank with the reader in or out.
Battery reads 12.15v, cleaned the terminals. Can't check amps at crank, but they're probably zero since it won't turn over. Tried starting in neutral instead of park. I tried swapping the ECU relay on the IPDM, no joy. Another post mentioned A/T ECU fuse, it's good. For grins I locked and unlocked it with the fob, no change. Called the stealership, service writer had no suggestion other than a jump - no clue on headlights or engine fan.
I'm open to suggestions. Thanks.
