07 brake replacement
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
suby01
Car: 2007 Infiniti G35x
so its time to get new pads 18k miles because my brakes vibrate and shake under hard braking. i have a question on the G's do we need both front and rear sets or does the back or front wear faster?havent really had a car with disks all way around. and the dealer wants 75$ each stillen has them for 50-60$. suggestions?
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
If you have overheated a set of rotors at only 18k I would recommend going aftermarket with them. Stillen has pretty good ones from what I have seen and Brembo is always reliable. I have seen the 07 sedans make it well past 30K with original equipment.
Had some pretty hard stops?
suby01
ya stillen does but they arent for the X, i was def thinking about those. hard stops possibly its me driving like a that got me there. haha.
so would you recommend changing the pads will that do anything or is just the rotors that are done. because it seems like i still have enough pad left on there and the rotors arent warped, but the brake light does come on once in a while, meaning its low.
ps. mods can you move this to the right forum, idn if it was moved or i just posted wrong to the brake section.
SteveTheTech
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
suby01 wrote:ps. mods can you move this to the right forum, idn if it was moved or i just posted wrong to the brake section.
LoL I didn't even notice that until you pointed it out. I fixed it.
I know from a quick Google on 07 Gx pads and rotors there are many options out there. There are many performance sets you may want to think of since you are driving your car in a more spirited manner than the OE brakes were designed for. Ill check our sponsors and see if any of them have offer an upgrade for you.
As for the wear on the pads. I do not know what you have left but if the brake light is coming on for low fluid than it's probably a safe bet that your pads are indeed worn out.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
