ezm »
https://forums.nicoclub.com/ezm-u106787.html
Thu Sep 25, 2008 6:46 am
fyi follow-up: dealer found that brake fluid was being sucked in vacuum line to the brake booster and removed the fluid from the booster. they said this was the cause of the smoke during cold (am) start-up.they installed a new brake master cyl., per recall and the there was no smoke this am, during cold start-up. smoke problem solved for good???
also, had cyl. walls boroscoped and they could see the normal? cross-hatching from factory honeing of cyl. bores. however, they could see carbon deposits and loose carbon sticking to cyl. walls (normal for only 1800 mi.?) - may be i need take a long freeway trip to try to clean the deposits up ???
does all of this make sense, or is some of it bs (from the dealer)????
