Larz »
https://forums.nicoclub.com/larz-u216291.html
Fri Jan 30, 2015 12:30 pm
I have owned an 07 M35 and now own an 09 M35. Neither had the sport option (harsher ride, btw if sport). My 07 was nearly fully equipped, but my 09 is 100% every option (including reclining temp controlled rear seats, rear sunshade, and rear DVD screen.
For me, the pros and cons list out as follows:
2007 M35:
5sp gearbox and VQ35 single intake engine. Worked brilliantly, but higher revs at all speeds compared to the 09.
Large 'school bus' sized tail lights, but better reverse lights than the 09.
Interior: no difference whatsoever between the two.
2009 M35:
7sp gearbox and VQ35HR engine (dual intakes). Shifting in AUTO or SPORT is not as smooth (it goes hunting in stop/go traffic)
On the plus side: I can do over 70 mph and still rev near 2,500rms - better mpg on motorway trips.
Front bumper is much more aggressive and rear tail lamps are normal size. Chrome trim adds a bit of posh without being gross.
Rain sense wipers - mehh, but the rear shade is great at night when the bloke behind you has wanna-be HIDs that are in reg headlamp housings which spreads the super bright light in all directions.
Lane departure is active instead of just beeping at you. Dash colors are absolutely beautiful.
NAV is HD based so you must have the dealer install updates even if you buy them directly.
I noticed no difference in the ride quality between the two - both have the right balance between sport feel and marshmallow on smooth motorway trips.
Options that you MUST get: Bose surround, NAV, bluetooth
