I was on http://www.recalls.gov (which does not have the 2006 M45) researching my friends 2006 Maxima (fully loaded) and noticed something strange. We've all heard of the loud noise coming from the rear end while driving and the Maxima has a recall for the rear suspension along with the front seats...______________________________________________________
Component: SUSPENSION:REAR (2006 Maxima)
Summary: ON CERTAIN VEHICLES, THE REAR SUBFRAME MAY HAVE BEEN MANUFACTURED INCORRECTLY, WHICH COULD RESULT IN A CRACK IN A BRACKET WHICH HOLDS PART OF THE REAR SUSPENSION.Consequence: IF THE BRACKET IS CRACKED, THE STABILITY OF THE VEHICLE MAY BE AFFECTED UNDER SEVERE DRIVING CONDITIONS. THIS COULD LEAD TO A LOSS OF CONTROL OF THE VEHICLE WHICH COULD RESULT IN A CRASH.Remedy: IF THE BRACKET IS CRACKED, THE STABILITY OF THE VEHICLE MAY BE AFFECTED UNDER SEVERE DRIVING CONDITIONS. THIS COULD LEAD TO A LOSS OF CONTROL OF THE VEHICLE WHICH COULD RESULT IN A CRASH.
Component: SEATS:FRONT ASSEMBLY:POWER ADJUST (2006 Maxima)
Summary: ON CERTAIN PASSENGER VEHICLES EQUIPPED WITH THE DRIVER PREFERRED PACKAGE, THE WIRE HARNESS FROM THE DRIVER'S SEAT POWER LUMBAR SUPPORT SWITCH MAY BE ROUTED INCORRECTLY AND COULD BE PINCHED UNDER THE DRIVER SEAT.
Consequence: A PINCHED HARNESS, IN COMBINATION WITH DRIVING VIBRATION, MAY RESULT IN A SHORT CIRCUIT IN THE HARNESS THAT COULD LEAD TO A FIRE IN THE SEAT.
Remedy: DEALERS WILL REPLACE THE WIRE HARNESS AND ROUTE IT CORRECTLY. THE RECALL BEGAN ON JANUARY 16, 2006. OWNERS MAY CONTACT NISSAN AT 1-800-647-7261.______________________________________________________
*When I had my front seat fixed due to the movement when braking, the wires were left hanging which made me wonder why they're not placed right. And the rear suspension part just had me thinking since Infiniti has yet to find a solution. So what do you all think? (lets not forget the Maxima is out little brother!) Also if you check out the 2006 Infiniti FX45 you will notice a "FUEL SYSTEM, GASOLINE" recall.*
______________________________________________________Component: FUEL SYSTEM, GASOLINE (2006 FX45)
Summary: ON CERTAIN PASSENGER AND SPORT UTILITY VEHICLES, THE FUEL FILLER HOSE MAY CRACK AND RESULT IN FUEL LEAKAGE FROM THE HOSE WHILE REFUELING.
Potential Number Of Units Affected : 192659 (which is only the FX45 and I have no idea if the fuel system is similar).______________________________________________________
Keep in mind that http://www.recalls.gov does not have the 2006 M45 listed, yet that doesn't mean there is no problem. I remember when my Lexus wasn't listed, yet I was up to three recalls.
Thanks for reading and hope it helps with something,D.
