06 QX56 Rear Brake Rotor Removal???
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
dagnew463
Car: 2006 Infiniti QX56
Has anyone ever removed the rear brake rotors? Is there a special tool or trick to get them off? Any help would be greatly appreciated! Thanks!!
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
should just need to take the caliper off and it will come off.
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
they're probably wedged on there and no amount of pulling/beating will get them off. there might be 2 holes in between the wheel studs, on opposite sides of each other. find a bolt that threads into them and crank it down on one side, then the other. eventually it'll come off.
dagnew463
Finally got them off!!!! It took half a can of WD-40 and about an hour of them soaking for them to finally free. Thank you to everyone's suggestions.
Return to “Armada Forum / QX56 Forum / QX80 Forum”
