Hawairish »
https://forums.nicoclub.com/hawairish-u243869.html
Fri Feb 12, 2016 6:23 pm
Doubt you'll find many people here who dive into repairs like that.
It seems reasonable to think that if you can get the bottom end off, you stand a fair chance to making the repair. But I can't imagine doing a repair like that while being on your back the entire time, let alone supporting everything for reassembly.
I'd be more concerned about related damage that you'd not be able to see or repair without having the engine on a stand. If the engines fails again for some reason, then the work is for nothing and you're back in this same situation with more to lose.
In your scenario, if an engine swap or repair can't be justified to make it worth keeping, then I'd say it's time to let it go. Given your history with the truck—and an unfortunate one at that—may be time to put it down.
