Due to the rain, my following answer may be all wet. The ignition switch module on my Pathfinder was faking out a bit over a year ago causing dash lights to stay on, sometimes, after I had turned it off and pulled the key. Sometimes, I couldn't even start the engine and nothing would turn on unless I played with the way I turned the key to start it. The slip-ring contacts in this ignition module are copper. There is a type of grease on the contacts that reduce friction and wear. However, over time and use, micro-particles of the copper contacts rub off, mix with the grease and prevent connections from contacting or create electrical connections when there should be none. The image in the following link is your ignition module, same as mine.
https://www.quirkparts.com/oem-parts/ni ... 487500m010 I was too cheap to buy a new one so I took mine apart, cleaned up its insides, and got lucky that it fixed my issues. I bought a new one later because I knew the old one was worn out and I simply bought myself a little more time by cleaning it up and I didn't want it failing again unexpectedly.
You may be able to test whether your dashboard lights are getting power through this ignition module when the ignition is off. They should if the ignition switch is on but they should not if the switch is off. This module is easily accessed on the left side of your steering column, under the plastic covers, just opposite from the ignition switch key. After you remove the top and bottom covers, held together by 5 or 6 Philips screws in the bottom side, you can unplug the electrical connector from the ignition module. Assuming your dashboard lights are on and ignition switch is off before you do any of this and then the lights turn off when you unplug the connector, then your ignition switch module is worn out. If that does appear to be the case, you may be able to take it apart like I did to clean it up but I can't recommend it. None of this makes sense to me regarding the rain.
