Zombdad81 »
https://forums.nicoclub.com/zombdad81-u275277.html
Mon Jun 26, 2017 10:29 am
About two months ago my Altima began running rough. At first it was sporatically. Every few drives it would run like it had water in the fuel or a bag plug (missing). I started with the easiest fixes. Lucas Fuel system treatment and changing the plugs, etc. At the time it was throwing cylinder misfire number 4 code. After doing all of that It started throwing multiple cylinder misfire code. As time went on the rough idle/in-gear has gotten increasingly worse. I begin to thrown cam shaft over advancement bank 2 code. So we changed the cam shaft sensors to no avail. Check Engine light is constantly on and Blinks in the rough parts of it. I had changed the radiator and flushed the system before this all began. I have also recently started smelling an odor akin to hot plastic/material or very close to exhaust after the car is shut off. I don't want to drop a ton of money into it as the car is so old but I cannot find anyone to give me a difinitive answer on what exactly is wrong. Some say timing, others has have said intake manifold gasket, some solenoid or cat converter. Please help! Thanks in advance for the info.
