hannibal »
https://forums.nicoclub.com/hannibal-u1252.html
Thu May 13, 2010 6:27 pm
My sister has an 06 Murano, purchased in Nov 2009. She recently noticed the A/C doesnt work. The climate control 'thinks' it does. If you if turn the temp to 'very cold' when its hot outside, it will blow on high fan speed trying to cool the car. But it is unable to cool and keeps blowing on high til you turn it off.
She took it to the dealer. First they said it must be a leak in the AC system. They called my sis and reported that they had found it. Then a few hours later they told my sis that the IPDM was bad.
This is the first time I'd heard of IPDM. I did some reading and I guess it could be the IPDM. I found a diagnostic in the FSM and I'll have my sis try it when she picks up the car tomorrow. But I'm assuming the dealer has already gone thru these steps.
I'm just wondering if a bad IPDM is a common problem on Muranos and if you think this may be her problem.
It seems like the IPDM is just a relay box with built in fusable links. Why did Nissan think it was a good idea to integrate everything into a single unit with irreplacable relays/links? I'm hoping there are solutions cheaper than replacing this $500 part.
PS: She also has experienced a hesitation just off idle. I drove it and felt the same problem. As you toe into the gas, it begins to accelerate, then hits a dead spot for a good 2 seconds. Then all is fine and it accelerates as normal. All this happens between idle and 2000rpm or so. Any ideas?
