gotbst05 »
https://forums.nicoclub.com/gotbst05-u148944.html
Sun Jan 03, 2010 9:43 am
it looks as if i spoke too soon. it worked great yesterday and this morning, it was acting as before. it never reaches 90F as it should and hot air only blows out when the car is in motion. as soon as i come to a stop, it blows cold air. i took it to the dealer i bought it from (a chevy one), so i'm thinking i'll call a nissan place to inquiry this issue. as anyone else had this issue or anything similar to it?
Murdered_T, i found a diagram that has the layout of the water pump and you're exactly right, it's attached to timing chain. design flaw? it really sucks that it's 15F here and my MO doesn't stay hot while sitting at idle. there has to be something to it. i'm going to rent a rad pressure tester and see what i get. the service manual calls for 23psi. it should hold at 23 and if not, well then, there's a leak in the system which is causing the air pockets. i was thinking about replacing the thermostat, but that appears to be a pain in the a**.
i'm taking the advice of Bishop and changing out the thermostat tomorrow. it sucks that it cost over $50 because it's the thermostat and housing together, but it should a fairly easy and messy job. according to service manual, i have to drain the radiator completely sucks, but it'll be an experience that i may be able to share with others that may have the same problem in the future.
Modified by gotbst05 at 4:06 PM 1/3/2010
