06 M45 Stumble/Stutter and fault codes
Matthewchristeson
Car: 2006 Infiniti M45 S
Okay everybody,
I am again asking for help. My M45 know has developed a stumble, the ABS, slip and vdc warning light comes on. Lights seem to reset and might stay off for a while without any issues. But when the stutter returns I back off accelerator, but the car continues to drive. The vehicle will do one of two things, from dead stop the car seems to have small stutter/miss but drives okay. The other thing it will do sometimes I'll be driving along at about 85mph or 3000rpm and the stutter will accrue, so I back off accelerator and keep at slower engine speeds and car will drive okay. I scan and have fault codes indicating C1185 accretor control, C1130 engine signal as well as P0335. I have replaced the crankshaft position sensors several times problem seems to be corrected but then will return. Any help would be great. My M currently has 316,205 miles. Any advice would be great.
Reason: Revise Title
LIBRILZ
Car: 1990 Nissan 300zx
2007 M45 Sport
316K?! That may be the highest mileage I've seen on one of these!
If the Crankshaft Position sensors are not OEM, problems will/can arise. Also maybe the plugs need to be changed.
