Again, as an Infiniti tech, "bushings" are done on an add needed basis. Replacing bushings during shock and strut replacement isn't going to save any money, as there is no overlap in time when replacing them. My M still has its original tie rods. They were so solid I chose to use a short rack when it needed the rack and pinion replaced. Meaning after 208k of Chicago roads, my tie rods are still good. It also has the original rear swaybar links, the fronts have been replaced. The swaybar bushings are still original. I still have the original upper and lower ball joints, control arm bushings, etc. There is absolutely no need to replace them as preventative maintenance in my opinion. My car still rides fantastic. If the car rides fine other than worn shocks, I'd just recommend replacing the worn parts.MOWellsinVA wrote:As you are probably aware, there are four stabilizer links that should be replaced.
What has been the experience of other drivers with bushing replacement?
Tramlining is caused by tire choice mostly, steering wheel shaking is a tire balance issue, and checking tie rods is one of the easiest at home checks you can do with a simple floor jack. M's typically have lower ball joints go bad before tie rods do, and even then, it takes some serious abuse or high mileage to typically need replacement. Your way of diagnosing a bad inner tie rod can apply to inner tie rods, outer tie rods, wheel bearings, etc.Sstupid wrote:If you don't have sever tramlining, unusual tire wear, a steering wheel that shakes while driving on smooth highway, or any strange noises when going over bumps or turning, then you don't likely have anything that needs to be replaced in the suspension, at that mileage. It is hard to diagnose faulty tie-rod ends but the inners are pretty easy to tell. Jack up the car with the ACC on. Grab one of the wheels and turn it while watching the wheel on the other side. If you see the other wheel turn at exactly the same time as the wheel you are gripping, then the inner tie-rods are good. If there is "slop" where the other wheel doesn't move immediately, then you have bad inner tie-rods.
Lift the side you're checking, take a huge pair of pliers and put one side on the bottom of the control arm and the other on the spindle were it bolts to and squeeze. They typically don't get any side to side movement that the traditional 12' o'clock and 6 o'clock wheel inspection shows, but they get up and down sloppy, If that makes sense. If you don't have any clunking or knocking going over bumps they're probably fine, as well as the rest of the suspension.MOWellsinVA wrote:Ho do you test the lower ball joints?
Shocks/struts are often the lowest hanging fruit.VegasJohnny wrote: ↑Sat Apr 09, 2022 8:50 amI have a 2007 M45 Sport with about 120k miles. It's in great condition overall but ride seems much bumpier than in years past. It's just a rickety ride for lack of a better word. I realize, reading a thread like this, there are different schools of thought. Has anybody replaced a lot of these suspension items and had a noticeably more comfortable ride? I don't mind spending money as I love the car still but I don't want to spend money if it doesn't do much. TIA.
PalmerWMD wrote: ↑Sat Apr 09, 2022 10:31 amShocks/struts are often the lowest hanging fruit.VegasJohnny wrote: ↑Sat Apr 09, 2022 8:50 amI have a 2007 M45 Sport with about 120k miles. It's in great condition overall but ride seems much bumpier than in years past. It's just a rickety ride for lack of a better word. I realize, reading a thread like this, there are different schools of thought. Has anybody replaced a lot of these suspension items and had a noticeably more comfortable ride? I don't mind spending money as I love the car still but I don't want to spend money if it doesn't do much. TIA.
Of course there are many more suspension components but this is where I would start. Especially in the front.
I once had an ancient Toyota Celica and I was on a real budget and all I replaced where front shocks and it really improved it by a lot.
YMMV of course.
PS : welcome to Nico!!!![]()
OEM shocks and struts are very expensive, most people on these forums replace them with KYB shocks and struts (I believe it is struts in front and shocks in the rear for these cars? IDK, doesnt really matter in the end).VegasJohnny wrote: ↑Sat Apr 09, 2022 8:50 amI have a 2007 M45 Sport with about 120k miles. It's in great condition overall but ride seems much bumpier than in years past. It's just a rickety ride for lack of a better word. I realize, reading a thread like this, there are different schools of thought. Has anybody replaced a lot of these suspension items and had a noticeably more comfortable ride? I don't mind spending money as I love the car still but I don't want to spend money if it doesn't do much. TIA.
Someone a year or two ago on these forums wanted to go super cheap and ordered some of these:cruzad3r wrote: ↑Tue Apr 12, 2022 7:48 pmKYB for the front is shorter than the OEM Strut therefore your alignment will be out of whack. I have them on for at least 50k miles already and it's time for new pairs. i seriously do not want to do that but the OEM are so friking expensive. i haven't found a coilover that's 4-500 dollars. if anyone has them on their car, do feel free to share.
That is because you have All wheel drive, but otherwise most folks will be fine.cruzad3r wrote: ↑Tue Apr 12, 2022 7:48 pmKYB for the front is shorter than the OEM Strut therefore your alignment will be out of whack. I have them on for at least 50k miles already and it's time for new pairs. i seriously do not want to do that but the OEM are so friking expensive. i haven't found a coilover that's 4-500 dollars. if anyone has them on their car, do feel free to share.
