This was interesting to me as my car launches hard and nice and straight. Always thought it has a LSD. I have always thought my car was a bit "special".
Did a few tests. Short little romp from a stop and then pulled up a bit:
Passenger:
Driver:
Rear:
Then, jacked up the car to drain the fluid---car in neutral spin a rear wheel and the other wheel spins in the same direction.
All of this is indicative of a LSD. I am just going to drain and refill (with Redline 75W90 Synthetic).
Can anyone confirm that LSD was an option on the M45S? If no one can confirm, the next time I do some work under the car I will pull the rear cover off and take a look at what rear is in there. I KNOW Cusco makes a type 2 LSD that fits in the Fuga/M Y50 pumpkin.
