06 M45 rocker panel bulbs
zach1104
Car: 06 Infiniti M45
Does anyone know what kind of bulbs go in the rocker panels to light up the "INFINITI "? My passenger side is a bit dimmer then the driver side
Ilya
I'm not sure...are you able to pry it open? My guess it's probably a couple 194 lights.
zach1104
That's what I'm thinking too. I'll just pop them open and see
Larz
Car: 2019 Q70-L RWD
The illuminated kick plates do not use bulbs. At each end of the assmbly is a soldered SMD that illuminates the plate with a difuser panel under the glass. You would have to remove the SMD on each end, then find an SMD with the colour you want, then re-solder the new SMD into place. Far as I know, it has been done on the multi-switch (A/C-NAV) but with much difficulty. I don't think anyone has done it to the kick plates yet.
Dean is the 'McGuyver member' who has pioneered most of the tricky lighting changes. Try searching his posts.
Ilya
Larz wrote:The illuminated kick plates do not use bulbs. At each end of the assmbly is a soldered SMD that illuminates the plate with a difuser panel under the glass. You would have to remove the SMD on each end, then find an SMD with the colour you want, then re-solder the new SMD into place. Far as I know, it has been done on the multi-switch (A/C-NAV) but with much difficulty. I don't think anyone has done it to the kick plates yet.
The AC/Nav modification is the in the FAQs (in my signature).
zach1104
Thank you for the help
