06 M35x wiper fluid annunciator light
pimpgixxer04
Car: 2006 infiniti M35x
Alright guys so i just bought my 06 m35x, the same night i bought it, the washer fluid annunciator was flickering, checked the connector etc, all good. now its stuck on steady. added fluid. still on. anyone have a part number for the sensor? also im missing my washer fluid cap. anyone have a spare laying around??
EdBwoy
28920-AR000 is the OEM part #
SU8136 from AutoZone for about half the cost of OEM
My autozone one has been holding fine.
pimpgixxer04
thanks man!
pimpgixxer04
so after researching those two part numbers, the 28920-AR000 number is the pump assembly, and the other number is the sensor, does the pump assy come with the sensor? the assy is cheaper than the sensor itself so if it does ill just go ahead and order it.
EdBwoy
Pardon the confusion. I copy-pasted the wrong item. They are different and independent parts.
The sensor is 28911-1E400. Not quite as expensive as the pump, but compared to the AutoZone part it would have taken longer to arrive/cost extra to ship. It depends on your circumstances.
I use this website to look for OEM part numbers:
https://www.infinitipartsdeal.com/parts ... 8911-1E400
