That fuse was indeed broken, I changed it, still runs rough, going to check the coil packs tomorrow while I wait for the spark plugs. MAF appears very clean so I havent tried cleaning it.EdBwoy wrote: ↑Sun Sep 24, 2017 5:12 pmHello and welcome to the forum. Might you have seen this thread?
p1148-and-p1168-closed-loop-errors-afte ... 14247.html
There might be some answers for your closed loop control issues. Check the fuse, then the sensors might be due for replacement.
No idea why they would run it without a filter, they're cheap enough to not risk it.
When you get a chance, also clean the MAF sensor (when cold), as it might have been compromised by dirty air. If you haven't gotten any codes for it, don't stress over it.
You're on the right track with the spark plugs. I think the PCV valves are not a bad deal either.
Keep the valve cover gaskets, air intake gasket and injector O-rings at the back of your mind. I don't change gaskets for the sake of it, but keep an eye on those.
Get the engine running right and hopefully you don't have to smell any more fuel.
Step by step will do it.
Super clean? Maybe there's been a previous attempt to clean the throttle body, and which would explain the high idle. Yes, run a scan. A P0507 might be lurking around.hellabuck wrote: ↑Thu Oct 05, 2017 4:28 pm...it is idling higher than our other m35 and im getting some white smoke from the exhaust now which is my concern now.
The throttle body was super clean, surprisingly a lot cleaner than our other M35 with half the mileage
Haven't checked the codes yet but will have a buddy come over with his scanner soon to find out.
Out of curiosity, did you find the electrical plugs loosely connected or was it that the bolts holding the coilpacks to the valve cover weren't pressing them down enough?
EdBwoy wrote: ↑Sun Oct 08, 2017 3:06 pmOut of curiosity, did you find the electrical plugs loosely connected or was it that the bolts holding the coilpacks to the valve cover weren't pressing them down enough?
Then, yeah, as Costee suggests you might have some idle relearning to do following that throttle body.
