Trying to give it gas during this time does absolutely nothing
Have you tried giving it gas just as you start the vehicle, in that it cranks while you jab the pedal, not waiting till it's about to die? Just curious as to whether this improves it at all
I did look like at some point a mouse got to my air filter because it was a little torn up in a corner. hopefully i didn't suck a mouse into my engine
The code does touch on the MAF as Ilya pointed out. Remove the unit from the intake tube and look inside to see if you find any mouse fur caught up and cooked of the MAF sensor.
PS: This won't be a problem on a non-running car, but remember to only mess with the sensor & cleaner after it has cooled down.
I noticed a few small tears in the flex pipes from airbox to TB but I doubt that would cause the car to be this bad. I checked connections and visually looked for any vacuum leaks
Actually air leaks also fall under that code. If these cracks go through the plastic such that the MAF is sensing X units but you are losing them in the cracks after it's already been metered, the car could act wonky.
I'm not saying this is impossible, but Ms don't have too many fuel pressure issues. The relevant tube feeding the engine is on the inner side of the passenger side front strut tower. You have to remove the plastic covers, but it will be the only rigid tube rising into the engine bay at that point and feeding the fuel hose across the engine.(If I find a picture, I'll post the area)
If you're up for a little more troubleshooting, swap the bank 1 sensor 1 and bank 2 sensor 1 from the pass side and driver side to see if the code jumps banks and becomes P0174. No idea what your mileage is, but sensors do go bad.
Or is this the sensor that is hard to reach in the V6?
