In any gear, both the reverse lights are locked on, and the back up cam in any gear, and it's getting really annoying while i'm driving now. I noticed that when the outside temps are above 50 degrees, everythings normal, and the back up cam usually doesnt turn on. I took my reverse light bulbs out just so i don't get pulled over or annoy people if not confuse them or scare them.
Does anyone know what this problem could be? I'm guessing there's a short somewhere. In accesory mode, i get the normal display and can adjust the heat settings, or music but otherwise i can't. Can't use nav either!
