USMC5811 »
https://forums.nicoclub.com/usmc5811-u215192.html
Fri May 15, 2015 6:42 am
Since you basically have a brand new car mileage wise it should be in very good shape. With that being said, it is still a 2006 and cars don't like to sit long periods of time without being driven, so there are a bunch of things you'll want to get in order before you start daily driving it hardcore. At the very least, I would say change the oil/filter ASAP and get some fresh gas in there because who knows how long the gas has been in there, and make sure you use premium unleaded gasoline. Also, visually inspect the tires for dry rot and/or flat spots. Check the date on the battery and get a new battery if the one in there is old.
If it were my car I would do a bunch of other things, but only because I'm a nut and most the maintenance i perform on my own cars could be considered overkill. But I would change the spark plugs, bleed the brakes and get all new fluid in them, change the PCV valve, change the air filter, and change the cabin filter just because the age of the car. Others might say that some of those things are overkill and aren't necessary, but IMO you practically have a new car mileage wise so you might as well make sure everything else is newer to ensure that the car will run and drive like it should and for a very long time. Good luck with your new car, I'm sure if you treat it right then it will treat you right in return and last a very long time!
