skim35 wrote:Sorry no pics but you can look up the wheel Work Varianza T1s I got the Black Chrome colorhttp://workwheelsusa.com/produ...el=50
Those specs for the rear should not be a problem. I am running a +38 offset in the rear 20x10 with the 275/30 tires. although they look fairly flush, I am getting spacers to push them out to +36. If you are worried you can run the 265's in the rear.
The fronts I am pretty sure you will fit, but not sure. I am running 20x8.5 w/ +36 offsets and high disc fitment. my tires are 245/35 the fitment now is fine but still a tad "in". I am going to also push the fronts out to +31 soon and I dont' think that would be a problem for me based on my current set up.
your 20x9 is the only thing I am not sure of. Also our fenders are already rolled...hehehehe done at factory, our M fenders don't have that normal lip, its nice and flat already.
I am also droped on coilovers... so I am lower then springs.
sweet wheels, I used to run those on my M....
good luck...
