coveredbridge »
https://forums.nicoclub.com/coveredbridge-u138540.html
Fri Jul 17, 2009 4:16 am
The iphone base pin configuration is different from the ipod and many (including infiniti) interfaces do not charge the phone. Another issue is that, while the ipod section of the iphone integrates pretty well with Infiniti's system, I'll often listen to internet radio, some podcasts on mediafly, etc which will only feed through the headphone jack. I just run the RCA adapter to the headphone out, a charger to the base pin connector. Apps like ORB allow iphone access to your desktop including music on your hard drive and even tv if your desktop has a tv card. Listen to tv on the commute home. Those, again, will only feed out via headphone jack.
