06 fx35 catalytic converter glowing red hot
A forum for lovers of Infiniti's hot-rod crossover, the FX! In 2014, all FX models will be named Infiniti QX70, in line with Infiniti's new naming structure.
guitfiddler
Car: 2006 Infiniti FX35
Hi Guys, been working on my daughters fx35 chasing a misfire. Seems like I finally got it sorted, however now the driver side cat is overheating. There is no misfire code confirmed or pending. I can smell the unburned fuel so I believe this is causing the cat to over heat and not a bad cat since I have just done a bit of work I am thinking I may have either done something incorrectly or a part is not playing nice. The misfire started after changing the plugs and coil packs Here is a list of what I have done:
2006 Fx35 w/ 230kmiles
New throttle body - hitachi - throttle body relearn done
Plugs NGK iridium - didn’t play nice so swapped with NGK platinum
New coil packs - aftermarket from Amazon - didn’t play nice swapped back to original
New OEM valve/rocker covers - oil in cylinder 5 spar plug tube
Refurbished Bosch fuel injectors - took care of the misfire - idles good but running rich
New cam/crank sensors - Amazon aftermarket - crank was bad so swapped all for hitachi sensors - still having a P0335 code - swapped back to original - runs better but still the p0335
Not quite sure where to go from here - after I changed the throttle body everything started acting up. Appreciate any help you can offer…
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Most Nissan ECM's get spark timing from the crank but injector timing from the cam, so it's unlikely the persistent P0335 is causing a raw fuel problem. Check those new injectors, I have a sneaking feeling you'll find one stuck open or badly-sealed.
guitfiddler
Appreciate the reply. Wouldn’t an open injector throw misfire code though? I did have the raw fuel burning before I changed them. Currently I have no misfire code and it runs smooth at idle. The CAT that’s over heating is on bank one. Would the MAF or a bad O2 sensor throw off the mixture?
VStar650CL
Technical Expert
Leaky injectors only cause misfires if they're severe enough to flood the spark plug, otherwise you just get lots of soot and lots of HC hitting the converter. If an A/F (front O2) is lying badly enough to cause a hot cat, it should also be causing codes, but you can diagnose most of that by looking at the A/F sensor outputs versus the STFT's. If the STFT is way negative but the A/F shows way rich, you probably have too much fuel coming in for the ECM to compensate, meaning an injector leak or high fuel pressure. If the A/F shows stoichiometry (normal) but we know from the cat that the bank is rich, then the A/F is probably bad. The A/F's on your FX are the early style. They read 1.5V at stoichiometry, lower voltage is rich and higher is lean.
VStar650CL
Technical Expert
PS - With only one bank acting up, you can pretty much rule out problems like the MAF or anything else that would affect both banks equally. On a dual-MAF ride that would be a different story, but when there's only one it will affect both banks.
Return to “Infiniti FX35 / FX45 / FX37 / FX50 / QX70 Forum”
