ricebike »
https://forums.nicoclub.com/ricebike-u5064.html
Sun Sep 11, 2022 8:28 pm
pretty simple as per FSM (that you can download for free from this site) page PS-20 with diagram of parts and other stuff after that page
REMOVAL
1. Loosen adjust screw and oil pump bolt, then remove belt.
2. Remove oil pump union bolts and hose.
3. Remove oil pump bracket bolts.
4. Remove oil pump.
INSTALLATION
Installation is in the reverse order of removal.
● Adjust belt tension.
Refer to MA-15, "Checking Drive Belts" (QR25DE)
● Bleed air after installation.
Refer to PS-6, "Bleeding Hydraulic System"
1. Raise the front end of vehicle until the wheels are clear of the ground.
2. Add Genuine NISSAN PSF or equivalent, into the steering fluid
reservoir tank to the specified level. Then quickly turn the steering wheel fully to right and left and lightly touch steering stoppers. Repeat steering wheel operation until the fluid level no
longer decreases.
3. Start the engine then repeat step 2 above. Incomplete air bleeding will cause the following symptoms:
● Air bubbles in reservoir tank
● Clicking noise in oil pump
● Excessive buzzing in oil pump
If this happens, bleed out the air repeating step 2 above. Fluid noise may occur in the valve or oil pump.
This is common when the vehicle is stationary or while turning the steering wheel slowly. This does not
affect the performance or durability of the system
