M4T5 »
https://forums.nicoclub.com/m4t5-u123303.html
Sat Aug 29, 2009 10:42 am
Just wanted to verify with some of you guys that there is a redesigned valve cover replacement TSB for the 06-07' M45's.
This was verified by my local Infiniti dealer service manager. He is not certain, but he believes this is only performed by a case by case basis.I assume your M45 has to be consuming oil or blowing blue smoke upon start up to have this performed. He told me that they would take care of this issue on my next oil change interval which is coming up in the next 600 miles or so. He also said they would take another look at the AC compressor's constant ticking noise and replace if necessary since they will be working on it anyways. *Side Note: Some 07' M45's that were built later in the year 2007 already came with the redesigned valve covers.
For you 08' & up M45 guys....you are out of luck! As you do not need the updated valve covers because you already have them!
J
Modified by M4T5 at 2:53 PM 8/29/2009
