DJPlayedYA wrote:Hey guys. I've been scouring through this forum in search of which y-pipes will fit a 2007 Infiniti M35 Sport RWD. There seem to be a lot of suggestions but I couldn't find any clear list of parts that might cross-reference to another Infiniti model (i.e. 06 G35 y-pipe fitting 07 M35?). Can someone familiar with the fittings of these y-pipes compile a list of parts and brands that would fit onto RWD and possibly even AWD M models? I think it would benefit the forum greatly. Just a suggestion but if someone does take their time to do this, thanks in advance!!!
First, I noticed that your car description indicates M45...but I'm responding to your M35 inquiry...
for the RWD, any VQ35DE ypipe and some VQ37HR ypipes...you can shop for G35 or G37 specific -- they work on the M35s. A lot of online parts stores do not cross reference the M35 fitment with the G35s since they did not have a large audience from the M's...and the G35s were more abundant (I think starting in 2003) It wasn't until recently that more M35s were being modified -- possibly the G35 owners stepping up to the M and still having their aftermarket parts and trying them on the M's... don't know for sure...
I have a lot of friends with modified G35s and when I picked up my M in 2010, they knew the M35 motor was the same and I began to experiment with other fitment swaps with the G35....
Log on Motordyne Engineering and you will find some intake and exhaust parts that is labeled on the site for both G35 and M35....
You can search my prior posts since I've talked about the many parts that I've obtained which fit directly from the G35s
as far as AWD, I believe the VQ37HR will work due to it's wide angled inlet tubing....
good luck....
