'05 Pathfinder HID's
mrmark
I bought these on another forum for my '05 Pathfinder, but had question on the install.
The instructional pic here has the "harness" already loaded with the wires from the ballast. My kit did not have the wires connected to the harness, just one white and one black wire with a spade connector. It did come with a socket, but it has 3 inlets. The factory harnes (9007) also has the 3 inlets with a green, black, and pink wire. This socket is suppose to connect into the stock harness. Which wire goes where.....
All the kits I've installed before had the harness connected....except this one of course.
Thanks....
NISTECH
You question is a bit confusing, If the kit has a harness with a connector that plugs into your vehicles connector why cant you just plug it in? Maybe a pic of what you did get might help make this more clear as to what the problem is. Sorry for the late response.
mrmark
NISTECH wrote:You question is a bit confusing, If the kit has a harness with a connector that plugs into your vehicles connector why cant you just plug it in? Maybe a pic of what you did get might help make this more clear as to what the problem is. Sorry for the late response.
Our Pathfinders have 9007 high/low bulbs. I took a volt meter and found which hot wire was low and which was high. I connected the lead to the low beam and now I have HID lows, but no high beam. That's fine...until inspection time....that's when I'll go back to my stock bulbs for the day.
