05 Pathfinder Fuel Sensor/Sending unit.
Rotorian
Car: 05 Pathfinder SE 4x4
Hello,
I need to replace the fuel float/sensor. I know I have to drop the tank. I have looked at a video, and have the service manual. It seems easy enough. One question on the fuel lines, do I have to squeeze the clips to disconnect or use a fuel like tool that spreads the clip?
Any other pitfalls? I have not really found a photo How to, but the videos dont seem bad. Ofcourse everything is easier on a platfrom, and I am just doing it in my garage.
Thanks for help.
Regards,
Rtr
atraudes
Car: 2001.5 Infiniti QX4 4WD
Welcome to Nico!
Unfortunately the only discussions I recall seeing here about replacing that sort of thing is for the 01-04 generations. I took a look through the FSM and it looks like it's all quick-connectors, where you squeeze the sides and the hose pops off. If you haven't already, give it a read.
What a bummer that you have to drop the fuel tank!! Makes me grateful for my razor-necked access hole :biggrin:
Good luck and let us know how it goes!
