Portek »
https://forums.nicoclub.com/portek-u313224.html
Tue Sep 03, 2024 6:07 pm
Hello guys,
Thanks that I can be part of this amazing forum.
I have a big problem with my Pathfinder from 2005 with the 4.0 V6. One day I parked my car without any problems and 2 days later it cranks but won't start. I checked it for fault codes but nothing interesting. I had no spark and maybe no pulse, so I checked all fuses, changed the relay for the ECM and changed both cam sensors and the crank sensor (not original because in Dominican Republic it is really difficult to get parts quick). After I changed them, I could start the car one time and it ran like before. After turning it off I couldn't start it again. This worked one time more on the next day and since this day it won't start.
It has no spark and I connected a lamp for seeing the pulse and nothing... I couldn't check the wires directly because I hadn't the wiring diagram for the ECM.
I disconnected the crank sensor to see if it was a failing sensor but no start. But the ECM recognized it. After that I disconnected both cam sensors for same procedure and also no start. But the ECM didn't recognize it. Could this be a hint for a bad ECM?
If I find a wiring diagram of the ECM for checking the cables I will control if there are circuits or breaks.
I measured the disconnected connectors for the cam sensors and could measure 12v on pin 1 and pin 2.
I hope you can understand what I try to explain. My english isn't the best and sorry for that and I hope that we can solve my problem...
