turbo691 »
https://forums.nicoclub.com/turbo691-u244001.html
Tue Nov 11, 2014 7:07 pm
Are you just completing the circuit on the ivt plug, or are you running a wire straight from the battery, to one of the two terminals? I have a similar issue, with an 03 spec v, and I feel like I have tried everything. The only difference with mine, is that I get an initial spark trigger, and then it cuts out. I have replaced the cam/crank sensors, ivt solenoid, throttle body, and pedal position sensor. It has power to the coils, 180 psi on all cylinders, and fuel is getting into the cylinders. When I turn the key, the car will sputter for a second and then just crank. The reason I replaced all of those parts, is because I was getting p0123-p0223 codes. Any help would be greatly appreciated. Thanks!
