05 Maxima Serpantine belt replacement
Tomsoxfan
Car: 2005 nissan maxima
Does anyone know how involved changing the serpantine belt is on a 2005 Maxima. Is this something the dealership should do ?
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
I know on my 95 I changed the belts on a lift removing the right front wheel. Not sure about the 3.5's.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
It's probably not too bad. Will probably be easier if you have a spare person (to hold the tensioner pulley while the other person fits the belt in place) but should be easily doable alone. I'll double check the exact process and confirm in a bit.
Tomsoxfan
Any word?
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Pretty straightforward, simpler than I suspected. Biggest issue is space, which isn't terrible. The tensioner is a screw-type, so this is an easy one-man job.
Page 11 here shows the process well. When adjusting the tensioner, don't forget you have to loosen the lock bolt through the center of the pulley itself before the adjuster will work. Then tighten it again when the new belt is in place.
