SteveTheTech wrote:
I prefer this method with some of the older units that have dark fluid or signs of wear on the transmission.
As for just draining and filling the trans if it were my car I would D&F at 30,000 intervals as it is cheaper and the fluid will usually last the 60k that it is recommended.
Exactly why a mechanical exchange is better on old expired fluid and varnished interior. A chemical cleaning agent and pressure is necessary to expell all of the old fluid, detritus, and varnish in solution with the cleaner (chemical flush agent). Also why internal filter screen and O ring require changing.
Drain and refill always leaves over 60% contaminated ATF. If this method is so good, why not also apply it to brake fluid, coolant, PS, refrigerant, etc.?
The answer is obvious, even for the scarecrow. Time to be in Kansas and quit dreaming about Oz.
