05 G35 Sedan 32K miles - bad rotors..
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
SOOOOO, I was replacing my front brakes and hoping to have the rotors turned at my local Nissan dealer.They tell me that if thy turn them to get the warp out, they will be out of spec.They tell me that it is normal Infiniti procedure to just replace the rotors.New rotors from Nissan are $110 per.The parts manager tells me he can get me drilled and slotted for around $237 per set.
Opinions??
I'm leaning toward the drilled and slotted as opposed to putting the OEM POS rotors back on.
I've had the wheels torqued to spec since I purchased the care NEW. Have never tracked it either. Just normal driving. Wonder if some SVT Cobra brakes would fit on my G!!! They were awesome! And I did push it from time to time...
Poyzinous
Car: 2004 G35x Premium 1976 Classic Red 36 inch #18 Radio Flyer Wagon...
How did you warp those rotors? Do you have a rear wheel drive G or an X model? The RWD has the big brakes. Part number 40206-EG000, same as the 06/07 M. I have only seen those warp on M45 models whose driver is a heavy braker. At 32k they should be resurfacable. One thing I do, is since I know my brakes last me 20k, at 10K I resurface the rotors and sand the pads down. And $110 sounds like the price for the 40206-AM800 rotors. The EG000 rotors would be like $130. unless in fact you have a G35x.
SVTCOBRA
How did I warp the rotors????? Are you serious??Please re-read original post.
Also, I have a RWD.
Apparently, they are just sh**y from the factory!!! Maybe they were made in CHINA like my filters are now.
We live in a relatively flat area. No heavy braking needed. No heavy braking made.
And, I get discounts at Nissan, so that's why the 'low' price.I'll probably get them at Napa since I get even deeper discounts there.
Now, I'm thinking about getting the non drilled/slotted.I'm now thinking I'll be OK with the ceramics.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Replace the rotors with OEM rotors and get some project MU NS pads.
No way in hell I would pay Infiniti stearlership prices on anything either and they are probably lying about the fact they can't be turned within spec and they have never been turned before. They are out to make money, bottom line and will tell you anything in order to do that. Take the rotors to NAPA and see if they tell you the same story. I wouldn't run the slotted and drilled on a daily driver, they won't be as quiet and are overkill.
http://www.infinitipartsusa.com
http://www.everythingg35.com
either of those two for the rotors.
http://www.mynismo.com
for the project MU NS pads.
Replace the brakes yourself. Your time plus $250 for everything and you are set.
joe603
Car: 2014 Durango R/T
I'd just go aftermarket....
http://www.forgedperformance.c...age=1
SVTCOBRA
Thanks Guys!!
Now, that I've put the car back together with the original pads and rotors...and the pads still have lots of life left, I'm still leaning toward the Napa rotors at ($41 per - with my discount) and possibly Akebono ceramics.Thinking I'll wait til the end of the summer to do them. So, I'll do more research on the Project Mu's too. The thing is that this is the wife's sedan and lately she has been talking about a white G37 coupe to replace it. IF the economy turns around next year and IF I can get a low mileage 2008/2009, we MIGHT trade.Also, JR gets his license this July!!! YAY!!!! Which means we won't need a sedan as much.
logicmobile
Car: infiniti g35 sedan
hi there , i have same problem my rotor is warp, well i do brake pretty hard but not like that bad...and i was thinking getting slotted stop tech on ...what is the bad thing on slotted vs. oem??? i thought that slotted is cooler and will not warp fast as oem does...
SVTCOBRA
logicmobile wrote:hi there , i have same problem my rotor is warp, well i do brake pretty hard but not like that bad...and i was thinking getting slotted stop tech on ...what is the bad thing on slotted vs. oem??? i thought that slotted is cooler and will not warp fast as oem does...
Been told that slotted/drilled will cool better and will not warp, but can not turn them, but prob never will need to.I'm going with ceramics this time around and possibly Napas best rotors (I get discounts there). Hope the ceramics will keep the heat down so that they don't warp.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
