05 g35 cranks but no start and the red security lights stays on
Twan 72
Car: 2005 Infiniti g35
Hey I'm new to the site I just brought a 05 Infiniti g35 I put a motor in it and I drove it for two days after I got it out the shop so the slip light came on and I was losing power I took the car back to the shop the tried changing out the wire harness now the car just cranks but don't start and the red security light stays on can anyone help me please
telcoman
Is there gas in the tank?
Is the fuel pump working and did you test for pressure?
Are you getting spark?
Telcoman
audtatious
Have them validate their work and trace wiring harness. They can use the FSM for reference:
http://www.nicoclub.com/archives/infini ... nuals.html
Twan 72
They said they put ether in the carborator or something and it started rite up
telcoman
Twan 72 wrote:They said they put ether in the carborator or something and it started rite up
Probably a bad flux capacitor?
Replace it
Telcoman
audtatious
Well, the G does not have a carb so they would have shot it into the intake. If the vehicle will start via ether then it's something to do with startup and they should be able to troubleshoot it via the FSM. In general, check fuel pressure at the fuel rail and also the cam and crankcase sensors.
Twan 72
Ok will check
