Tampa G35 Sedan 6MT »
https://forums.nicoclub.com/tampa-g35-sedan-6mt-u77425.html
Wed Sep 30, 2009 8:34 am
The 05 is different than that one! (now that i look at it Much Easier)
Remove the shifter, and that part of the consol.
Then remove the aluminum trip that crosses the dash
Then YOu remove the the two screws that hold on the the two side pieces that are located under the shifter cover and they unclip from the sides covers of the radio. (The ones that are shown in the pics that you have to go in the glove box)
You then remove the top cover over the clock... Pull out towards you...not up...
Then You need to remove the cover that is below the clock... It is the flat part (Plastic) (also pull out towards you)
Below this plastic of the clock their is one screw. (This will be the screw that you will want to put back first... Makes it much easier if you ask me)
Then You remove the two screws on the bottom of the radio and along the side. (Not the ones that hold the face on... Don't want to remove that as it will cause issues with your screen. [don't ask me how i know ])
Pull the radio stright out and then down and the top screw bracket will clear the dash... (Be careful not to scrape the dash up when you take it out and put it back in!) I used a towel to cover my a$$ lol
Then you install the two connectors and make sure you put the wires where you want them... I made the wire come out in between the driver seat and the center shifter... it was easy to wire that way!
Good luck and shoot me an email if you have any more questions...
DJ
