05 g35 coupe ENGINE STALL while driving ...help!
roofrecon.com
Car: g35s sedan 2007
The dealer says they can't troubleshoot this because there are no codes and no hints and can't replicate the problem. It happens once a month while driving and putting my 6speed in neutral under no stress and coasting for about 5 seconds before going into next gear...rare I do this but good stick drivers use momentum to actually roll for a bit sometimes until changing gears. One time I was turning and slowing down and it totally cut off and all the dashboard lights came on ...lost all power steering. I have no idea what to do. I run an AEM cold air intake from the ground, cat back borla exhaust system..but I swear this was happening before all this...bad MAF? bad temp sensor? ...
Q45tech
Common on owner redesigned G35 intake cars................changes the turbulence in MAF sensor............when you sudden go to neutral the air flow is distrupted.
The MAF and integrated AT sensors are usually damaged because of your changes in filtration...............not enough to throw a code but enough to cause the temporay failure...........resets when you recrank.
Return to oem air filter and box should solve your self induced problem.
roofrecon.com
as I stated in my note...this happened before added the AEM intake and it was professionally installed.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Perhaps, but you are still going to have to at least return to OEM intake configuration to diagnose. Dealer has no obligation now that it is modified.
How about the "professional installer"?
roofrecon.com
actually the dealer said he is obligated that's why he's keeping my car and he trurned over a 2007 g35 to me to drive for a week now. He said the intake and muffler system didn't void anything and if the car were to be in a crash infiniti would be liable for everything...especially since they now have it. Hopefully they will find something soon.
Q451990
Sounds like you have a cooperative dealer! I hope they find it too. If they find the problem, please keep us posted...
Heath
Q45tech
All the other 3 - G35 sites discuss this happening just after installing a CAI or modification of the intake system on manual transmission vehicles when placed in neutral at speed.
Just like what happens when you use a cone fliter in close proximity to maf element the calibration changes because the air flow turbulence changes.
I have seen cases where a maf will read lower with a cone filter than oem the exact oposite from what you would expect..........however the leaner mixture [from the 0.1 volt lower signal] makes at bit more power on the dyno.
The screen filter on maf is designed to isolate the MAF somewhat but in a sudden shockwave from a TB closing it may distrupt the signals long enough for ecu to hiccup...............a combo problem from drive by wire TB and maf scan time......................a longer time constant [maf sample/change rate] could cure the problem.
As far as I have read everyone who reverted to oem air intake cured the problem!
roofrecon.com
this was happening before the intake was added
