kmckis1029 »
https://forums.nicoclub.com/kmckis1029-u103545.html
Wed Oct 09, 2013 1:10 pm
just found out this... if you want to go to the "dark side"... lol... you can completely disable the VDC system if you put a switch on the YAW sensor wire, which is under the arm rest center console. This will keep the ABS system intact but put the VDC system in fail safe mode. the "SLIP" light on the car will stay illuminated until the YAW sensor wire is reconnected and car is power cycled.
another way to put the the VDC in safe mode is to throw off the YAW sensor. I noticed that when i was at atlanta motor speed way and i sat on the high bank of the curve too long my VDC would go into fail safe mode; as it thought the car was flipped on its side lol.
this has been confirmed on other forums where people report actually being able to do a standing burnout in their Gs when at the track.
