05 G35 - Clutch Pedal Sticking
Pauls98SE
Car: 2005 G35 Sedan
I did some searching and found a thread started for exactly the same problem, but no replies. Hopefully I can get some advice.
First off - 2005 with 58600 miles and up to date service history. I have owned the car for 2 months.
The problem I have is the clutch pedal sticks on warm days (75+) when it is being released. The pedal sticks about 1-2 inches from being fully released. I can pull it back up with my foot and it stays. During colder weather there is no sticking.
Other items that may or may not be related. Intermittent popping (almost like a catch) in the pedal when being pushed in and when being released. Popping is intermittent, but not related to warm or cold temps. I hear and feel the popping on both the push and release. Occurs about 1/2 way through travel both being pressed and released. Fluid in Clutch Master Cylinder has a definite brown color to it compared to the fluid in Brake Master Cylinder. This causes me to wonder since both are the same brake fluid. Driveability is not effected by the sticking pedal. I have no slipping, no strange noises or anything leading me to believe I have a bad clutch.
Dealer says it is the clutch and will cost $1900. Says weak springs are the cause for pedal not coming back up. Took the car to a transmission shop for a second opinion on the worn clutch. They agreed with me that there did not seem to be anything wrong.
I am almost to 60k and if this is hydraulic issue, I need to get dealer to repair under warranty.
Thanks for the help!!!!!
Pauls98SE
Car: 2005 G35 Sedan
Lots of views and no posts...Anyone able to throw in their advice or experience?
fixer
Car: 08 Sentra
if the springs are weak on the clutch disc it should be still covered under warranty. that seems like a defect in manufacture, as long as the clutch is not worn out. or if clutch has not been abused. I would try blleding the system first. If it doesnt get better then a slave cylinder next. usually fixes it. when the clutch wears the pedal gets higher and harder to push.
Mtrappo
Car: 05' Infiniti G35
i just had my clutch, flywheel, slave & master cylinders replaced and the problem still exists. i was told it is the clutch pedal assist spring and bushing.
i am going to replace those next.
Q451990
I'm sorry for the slow response. Here are a few threads that may help.
post5536239.html
post5253247.html
post4858888.html
I hope this helps!
Heath
dalanamorse
Car: 2006 Infiniti G35 Coupe
My clutch pedal had been sticking at random times for over a year. The problem was so sporadic and the dealership was 30 minutes away so the sticking pedal problem would stop sticking by the time I could take it in and show them the problem.
About a month or two ago, I took it to Grubbs Infiniti in Euless, Texas, for the airbag recall and mentioned the sticking clutch pedal to them. Of course, they were unable to replicate the problem so they were not able to fix it and sent me on my way.
On December 9, 2010, I took it in again because I could smell that awful burning clutch smell. The dealer wanted me to pay $1,450.00 for the repairs. I have an extended warranty on the vehicle but normal wear and tear is not covered. That is understandable but it still was not good enough for me. I knew that the sticking clutch pedal was causing wear and tear that was BEYOND normal on my car – especially since it had been doing it for over a year.
By accident, I stumbled across this forum and MULTIPLE other forums of people have the EXACT same issue with their G35’s. I also found MULTIPLE forums of Nissan 350 owners with the EXACT same problem – after all it is essentially the same car. I was shocked and appalled that this has not become a recall issue when it is a matter of consumer safety. I think that this issue is bigger than any of us or Infiniti/Nissan realizes.
Even more shocking and appalling is the lack of concern for my safety that I received from both Grubbs Infiniti and Infiniti Consumer Affairs. Their complete unwillingness to make the needed repairs and cover all or part of the costs and STOP putting my life in jeopardy every time I drive the vehicle is asinine.
Infiniti/Nissan’s defective sticking clutch pedal IS A MAJOR SAFETY CONCERN and does cause premature wear on other clutch parts. Therefore, Infiniti/Nissan should:
  • Issue a recall on this sticking pedal IMMEDIATELY. People’s lives are at risk! This is no different than the sticking accelerator problem that Toyota had but they want to sweep it under the rug. DOES SOMEONE HAVE TO DIE BEFORE THEY WILL WAKE UP?
  • If they aren’t going to recall the sticking clutch pedal, then they need to cover the repairs to fix the sticking clutch pedal and any repairs from the unnecessary wear that the sticking clutch pedal caused.
If you have tried to work with the dealership or Infiniti/Nissan to get them to do just those very things and your attempts failed, here is what I suggest you do, as suggested to me by a consumer attorney:
  • File a complaint, in writing, over the phone or online with the National Highway Traffic Safety Administration (NHTSA) by going to https://www-odi.nhtsa.dot.gov/ivoq/index.cfm
  • File a complaint with the Attorney General – Consumer Protection Division in your area. You can find a list by state by going here: http://www.naag.org/current-attorneys-general.php
  • Write your congressman or congress-woman. You can find yours by going to https://writerep.house.gov/writerep/welcome.shtml. The last thing Infiniti/Nissan wants is a criminal investigation (much like Toyota’s) into the company's safety problems and lack of concern for their customers.
  • Contact a public defender at your local news station. Almost all of us have them now. You may not get a call back or response from this but I am willing to bet that if we all do this, one of them will step up the plate and broadcast this problem. And if you know how the news works, when one reports it, they ALL report it. News broadcasts will bring more people forward with the same problem and will provide us Infiniti/Nissan owners with some strength in numbers.
Having lived this, I hope that my tips and pointers help.
In addition, if any of you are in Texas and would like to become part of a group lawsuit against Infiniti/Nissan to offset some of the attorney fees, please email me at [email protected]
United we stand… Let’s come together and MAKE Infiniti/Nissan do the right thing since they obviously aren’t going to do it on their own.
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Pauls98SE wrote:I did some searching and found a thread started for exactly the same problem, but no replies. Hopefully I can get some advice.
When is the last time you flushed your clutch fluid.
If it has been a while try using the gravity bleeding method.
I have a 20oz water bottle with a small clear 1/4" hose submerged in a fluid reservoir of old fluid (to prevent back flow). Get a new pint of brake fluid and poke a hole in the foil liner and turn it upside down onto the reservoir and allow the fluid to flush for a while to flush the system with no pressure (preventing potential damage to anything).
I bet if you look at the clutch fluid it looks like an IPA.
At least that is if you are lucky. If the clutch is actually sticking at that point the pressure fingers or throwout bearing might be damaged.
Let's try hoping for the easy things first. :dblthumb:
MoonRivertttt
Car: 07 G35 Coupe 6MT
I hope that you have already fixed it, otherwise it's a simple adjustment, just a few turns of the pedal push rod to raise the pedal a bit should fix it. I had this problem on my 07 G35 6MT and done that, it has cured the problem, nothing else needed to be touched, not clutch fluid, not master slave cylinder nor anything else. How to adjust the rod follow the link below
(link to outside forum removed)
I believe it works for your 05.
