to NICO Jfine!
I think the LED that the OP was referring to is on the 7 to 4 converter...
Are your tail lights and signals working correctly on the truck itself?
Check out this link to the tow harness kit, with installation instructions.
http://www.courtesyparts.com/receiver-h ... 28543.html
It's also worth noting that the factory produces a 4 wire kit, so if you end up replacing components anyway, you could go back with that.
http://www.courtesyparts.com/betasite/r ... 28542.html
There may be a wiring diagram in the factory service manual, available at
http://www.nissanservicemanual.com, that could help.
