05 Frontier rear axle assembly-newbie
benjaminr
Car: 05 Frontier Crew Cab
My 05 Frontier Crew Cab (4x2 non off road) needs a new axle assembly and my mechanic keeps striking out with what is sent from the salvage yards. Apparently the 05 model had quite a few different axles and they aren't interchangeable? The axles they send do not fit (problem with yoke). The mechanic is ready get a new one (almost$3000 just for the part!). Apparently Nissan doesn't sell the parts to rebuild-only the entire assembly. I just need to rebuild the differential. Any advice? Thanks!
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
hm.
First year of second gen.
Got any casting #s on it? Thought they were all the D44 variant, but the 2wd truck might have a C200. Both would have a similar bolt pattern on the cover.
Best bet is to look at the axle code in the door jamb equipment sticker and match that to a truck in a junkyard. That way you now you're gettting the same thing.
benjaminr
Thanks so much for your advice, Desert Rat. The axle code listed on the door was wrong. Although I'm certain there is a salvaged axle out there,neither me nor my mechanic has been able to locate it. Unfortunately, after a week and a half of looking with no success, I was forced to buy a new one. Not the route I wanted to take, but it's time to get back in the road. Thanks again for your response.
