VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Sat Mar 15, 2025 4:51 pm
If there are no lights, first make sure your battery connections are good. The shift lock works off the brake lamps, so if there's no power to those then the shifter won't move without using the emergency shift popper. To check the hot lug, turn the ignition on and put a voltmeter from the positive post to one of the smaller bus bars on the opposite side of the link box. You should show at or near 0V, if there's a voltage then your lug or your link attachments have a problem. Don't mess around with that, on a Frontier you have about a 50-50 shot at blowing up your ECM if the hot terminal sparks while trying to crank. Replace the lug with a proper one (24340-7F000, there are clones all over eBay and Amazon) and don't take chances. If that all checks out, see if there's juice at one of the battery fuses in the cabin fuseblock. If not, check the smaller links in the underhood fusible link box. If there's juice at the cabin fusebox, get at the ignition switch (back of the key cylinder) and see if you have juice at both the Red and White/Green wires with the key in the On position. If not, your ignition switch is bad.
