05 Altima SE-R - Akebono Brakes question
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
USC Justice
Car: 88 Nissan Desert Runner
02 Nissan Pathfinder SE 4x4
05 Infiniti QX56
09 Infiniti G37 S Vert
12 Nissan Pathfinder Silver
15 Infiniti Q50
OK, working on a few different projects with my SE-R Altima. Ran across the opportunity to pick up the Akebono brakes from the 370Z (big brake kit). I have searched and found nothing relating to this and the stock SE-R wheels. I have seen in another forum where it has been done with a 4th gen Altima which had 19 inch rims.
Short version I'm looking at picking up these calipers if they will work with the stock SE-R wheels. Does anyone know definitively?
Thanks in advance.
RicerX
Car: '20 Titan Pro4X
Jog my memory - what size are the SE-R wheels? Also, offsets?
USC Justice
05 Infiniti QX56
15 Infiniti Q50
18 inch wheels +45 offset I believe.
RicerX
Ah. I remember now. Those should fit without a problem - the temporary spare in the Z is an 18" wheel (which would obviously have to clear the brakes) and the OE sport package wheel has a 47mm offset in the front (on a 19x9 sized wheel) so I'm pretty sure they would fit without issue. I would test fit them - at the most you'd need some 10mm spacers or something, but I doubt that.
Post up some pictures after you're done!
Return to “3rd Generation Altima Sedan (2002-2006)”
