Rcypert »
https://forums.nicoclub.com/rcypert-u295239.html
Sun Sep 27, 2020 8:51 pm
Hey guys I cannot wrap my head around that FSM yet. I keto getting lost in the volumes of information. I need help with this no start issue I’ve been chasing fir a week now. Finally got it narrowed down to injector pulse. Sparks good fuel pressure is 49psi. Car runs if feed has down a vacuum port. It’ll run for up to a minute. Injectors spray nicely if I touch a 4volt lithium ion battery to them. It’s definitely the signal from the ECM that’s not working. I get strange voltage readings at the harness sometimes close to 12 sometimes 9 volts sometimes less than a volt. Not sure where to start trying to figure this out. New camshaft position sensor. Removed and cleaned and tested the crank sensor. It had resistance so I thought it was good. Not sure the specs on it. Thanks in advance for any help.
