05 350z Timing / Engine Swap
Nissan 350z / Nissan 370z technical discussion forum: Maintenance, performance, installations, modifications, how-to's and troubleshooting.
cajuncustoms
Car: 2004 Nissan 350Z
2005 Nissan 350Z
Original Harness
cajuncustoms
2005 Nissan 350Z
Harness i bought
cajuncustoms
2005 Nissan 350Z
so different part numbers im very curious as what wires are different
cajuncustoms
2005 Nissan 350Z
hrmm both these part numbers are the protector for the harness from what im finding and there were no other numbers
cajuncustoms
2005 Nissan 350Z
ok so i found this picture on a harness that was for sale , i know where this location is , on the harness i bought that tag is gone , on my harness thats where the dogs ate it , so is there another way to find the correct part number ?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Assuming the engine is original and didn't get swapped before you bought it (omfg if that's the case), you can go to NissanPartsDeal.com and plug in the VIN. NPD is a consortium of Nissan dealers and their dbase and drawings are the same as Nissan EPC that a dealer uses, so whatever p/n you turn up is guaranteed to be what the car was built with. Nissan calls their engine harnesses an "EGI Harness", so if you search EGI it should pop right up, along with a couple sub-harnesses for the same engine.
cajuncustoms
2005 Nissan 350Z
i think this is the correct one its called engine room harness
cajuncustoms
2005 Nissan 350Z
Nissan 24012-CD210Harness Assy-Engine Room
cajuncustoms
2005 Nissan 350Z
it says 2003-2006 Nissan 350Z 24012CD210
VStar650CL
Technical Expert
Nope, you need EGI and not Engine Room. Engine Room is the "E" Harness in the WD's, EGI is the "F" Harness. The right one should have a 24011- prefix. For most Nissan parts, the first five digits represent the type of part, the last five represent the version and what it fits. EGI harnesses are 24011's.
cajuncustoms
2005 Nissan 350Z
got ya Nissan 24011-CD810Harness Assembly-EGI
2003-2006 Nissan 350Z 24011CD810
cajuncustoms
2005 Nissan 350Z
VStar650CL wrote:
Thu May 26, 2022 7:57 pm
Thanks for the help on this , crossing my fingers think you might have figured out my problem , ordered the only harness on ebay with the correct part number , installed it today , fired right up sounds fine , no check engine light , i reved it multiple times no light , cant move it atm getting ready to replace the suspension but i think this might have been it. Thanks alot
VStar650CL
Technical Expert
You're most welcome, glad you got it straightened away. Happy motoring! :woot:
Return to “350z / 370z Technical”
