MaxBolus »
https://forums.nicoclub.com/maxbolus-u65637.html
Fri Aug 17, 2007 3:26 pm
hi-
recently started to notice the front end seems to 'dig in' during hard stops, even getting some front tire slip.. Almost as if the rear brakes aren't grabbing?
I did change the rear pads a few weeks back, prolly have 2k miles on them by now, but this issue just started a couple days ago.
Fronts have slotted/drilled rotors, good pad remaining. ceramic pads all around (rear rotors stock). Fluid level good, pedal feels OK...*maybe* a bit soft, but I could be overly sensitive..
Haven't gone to the dealer yet..but want to get an idea. (e.g., could bad struts cause this, or do I have some kind of brake system problem?)
thanks!
